Quick Radius Rod Question
Almonte Ontario Canada
Just wondering if there is any easy way to adjust the arms to set up the front suspension, Looked at it today and it looks like a crows foot will be the easiest to break the jamnut loose so you can adjust. Has anyone else done this before? If so what did ya use? Lol it doesnt appear to be easy to do once the trailing arms and everything are re-attatched. I dont really want to pull the pipes again and completely remove the rods that way either unless I have to.
Thanks!
Best way is to pull the pipes, as you need a wrench for the heim joint and the jamb nut, as well as enough space to work in.
