justin1620
Hey fellas, at the end of last season I was leaking oil out of the small power valve gasket. I changed the gaskets this year. Still leaks oil. After taking a look at the powervalve servo motor and revving it up it looks like the pulley is trying to turn once in a while but no consistently. I figured the pulley should be rotating back and forth after 900 rpms. I revved it to about 4500-5000 and it just kind of jerks back about 1/4 of an inch every once in a while and sometimes it wont move at all for a while while the rpms are up. I'm assuming this is the cause of my gasket seals going on me and would this be as simple as replacing the servo and re adjusting, or should i try to re-adjust this unit? thanks
