reed spacers
toofast
maine
can any body tell me if reed spacers behind stock reeds work better than v force reeds thanks
From reading the posts on here, using the stock reeds is best with a stock motor. Spacers dont do anything really for you... Best to invest in good clutching and get the power to the ground. No need to really put v-force in unless your doing engine work, and even at that some guys on here will still argue to run the stock yammy reeds, they definately do the job :)
Reed spacers work great on any yammie triples with stock reeds.
More flow...more go.
We have a local engine/pipe builder that tested em on his flow bench. He found pretty decent gains on ANY yammie triple he tested em on.
i forgot to mention my sled has a hauck clutch kit so i think i will take out the v force and run stock reeds with spacers does that sound better turk thanks
if the v force are allready in there don,t bother changing em.
