srx track
toofast
maine
when my sled set flat on cement floor in garage the back track sets up you can look under it it doesnt set flat what adjustments does it need or do they set like that thanks
how much under the back if its like a 1/4-3/8" thats normal if the front limiters are let out a tad for better traction, if its like 2-3 inchs then its out of adj.
post back answer, thanx
what to do to bring the rear end to the ground
mine is like that too about 2 inches underneath track in back ,what adjustments do you do to it first to get it down thanks
if its up that far, first thing would be to put a thin 2.5mm thick shim on the bottom side of the transfer rods. if yours has the fat one, either replace it or cut it in about 3pc and install a thin one.
