Servo Question
plumber
Michigan
I have a 1998 SRX 700. Does anyone know how far the servo pulley is supposed to turn when hooked up to the test plug? The power valve cables are disconnected. Also my test plug has three wires, two red and one black. For some reason my servo turns at least 360 degrees one way then 45 degrees the other. It also never stops at the same place twice. Does pretty much the same thing when the sled is started.
