the tree man
2000 SRX 700.I see the coolant slots in the base gasket above the exhaust ports are staggered.End hole is larger than the other two.Does the bigger hole go on the mag or pto side?This thing has been replaced prior to me owning it and I want to be sure they knew what they were doing.
install base gasket so that the side with elevation faces upward.Also the edge with the notch should between cylinder #1 and #2.
the tree man
Thank you.
