engine bog 4000 rpm
shanesz28
Weidman Mi
Just cleaned and adjusted the powervalves, and cleaned the carbs, on my 2000 SRX 700, took it out for a run in the grass and clutch engages at about 4000, i hold it just under engagement and when i nail it fast or ease into it it has a slight hesitation, where should i start, i havent rode the sled i bought at the end of last year so i am not sure if it has been like this for awhile.
Check your fuel screws,,, turn out to 1.1/2 turns and try it .. Got mine at about 1&3/4.. Also helps with idle hang..
Been awhile since i messed with carbs is the fuel screws you are talking about the ones internal between the main and the float
It is on the bottom side of carb (external) still need to remove rack to get at them...
