2000 Mountainmax 700 Jetting
sledn
Here is my setup: 2000 MM700 with Power Inc end dumps, reed spacers, airbox mod, 1laver of head gasket removed, 2.5 inch flowrites in dash. What should be my jetting for 1500ft and lets say 0 deg. I will be using variflow when going to the moutains. Any suggestions would be great. Right now i have 145's stright across with 52.5 pilots, with screws out 2 turns. Let me knwo
You are scarey lean on the mains. I would run 147.5-148.3-148.3. Raise the mag & centre needles 1 notch & the pto 1/2.
Here is another question? I had the sled runnig in the drive for about 5 minutes and noticed oil/gas about the size of a basketball on the driveway under the exhuast. Do you have any ideas. It couldn't be so rich that raw fuel in making it out of the pipes, could it. I have no clue.
