M_Persson
- Feb 15, 2006
Hallo.
My VT will not work very well.
On idle it just work on one cylinder but if i put choke in first step it work ot both cylinders. In higher rpms the engine run like it should.
I have clean both carbs and also change fuelpump and sparkplugs.
Do anyone have a solution on my prob?
Sounds like it's seized.
did this problem just start or did u buy it this way? could be carbs arnt insink or maybe the crank seals or just do a quick spark test . pull a plug wire off with a spare plug see if u get spark out of that cylinder at idle. if one side doesnt spark it might be a weak coil
Yamadooed
If it just started and ran like this out of storage drain all fuel flush the tank and lines with fresh fuel and clean and soak carbs. Read your spark plugs Ill bet their toasty white and not chocolate brown.
