Srx 700 bad supension problem
Garett0
byron
i just took out the skid to install a new rail, i put it all back together , and the back sits up high enuff to put the front of my shoe under it , my straps are loose , i loosened up front shock to see if this would help , and nothing , this thing sits up from the two front wheel back its off the ground? how do i push the back down ? my straps are 1 inch thread showing, im 220 pounds , it looks funny , ive never seen a sled sit like this? seems like the ski's will be off the ground all the time and i wont be able to steer? please any info would be great as this is my first srx
when we took out the skid all id did was take off ls rail and replace , i also loosened the straps up , as the old owner had the sucked in a lil bit , like i said i have 1 inch showing on threads , i think max is 10mm , we ran track adjusted it everything seems fine, beside the back sits up
Not necessarily, how hard was it to get all the bolts back in the tunnel?
Did you have to fight any of them real bad?
not to bad at all really , can someone post some pics of there skid so i can see the angle of the mounts
Why did you loosen your limiter straps? Doing this will allow the front of the skid to drop out further and could be the reason why you are noticing the rear of the skid being held up.
How does it feel when sitting and bouncing up and down on the sled? Does it seem to react normal? Or is it extra stiff compared to before?
Pics would be nice to help narrow down the problem.
the reason being was ,the old owner had them suck up quit a bit , and i was told this puts more front pressure on ski's , = less traction, so i loosened them to 1 inch exposed threads , heck even if i sucked it tight all the way , i still think it wouldnt be right , any pics would be nice
