coolant
I don't know as there's any preferred coolant to use as long as it's compatible with aluminum,personally I use whatever the local auto parts store has not necessarily the cheaper stuff but green and mix it 50/50.Some guys like to mix it 60/40 but I think most manuals will state to use 50/50.
60 anitfreez/40 deionized (distilled) water per manual. Dont use tap water as the crap in the water is what starts the corrosion. But any 50/50 will work also. Just make sure safe for aluminum like fourbarrel said. CCC
That's a good point too about using distilled water instead of tap water,especially if your like me and are on a municipal water system that's chlorinated.
Guys go to your local ford dealer and pick up some motorcraft premium gold. I think its the best on the market. I use it in everything and have never seen any corrosion from it. Ive opened up alot of engines well over 100k that have been spotless. I run it in my gm's as well. Dex-cool sucks.
Any 50/50 is good,,, do you have a rear heat exchanger on it? If not get one...........Helps out the most,,,, for the hot viper.......
