leaking oil
snopax
Wisconsin
Hi guys... Im having a pretty healthy oil leak from under my center power valve housing. After finding the leak I pulled and cleaned all of the power valves and replaced part 23 (see image) but it is still leaking, even worse now. Anyone know what parts need to replaced to stop this leak?
Edit:
Also wanted to add, the choke lever for some reason seems to be binding. It doesn't automatically re-seat when releasing, I have to manually push it in... Bad spring?
Remove And Check For Cracks Mabey You Tightning To Much ,and You Probobly Need A New Choke Cabel And Or Carb Cleaning
Thanks for the help guys... I figured that is what I was looking for. The other gasket needed replacing anyway as it was missing in the first place :)
Winderosa makes a complete power valve gasket kit . Its only like $26. Part # is 0934-0863. Picked mine up at dennis kirk. Does all 3 valves too.
