secondary degree adjustments
snoprokidf6
Lee Center, NY
does anyone have a chart that shows you what settings you need to get a certain degree on the secondary clutch, i've been adjusting the clutch via the helix and the holes in it, after taking it completely apart i've noticed some other holes behind the spring, just wondering if anyone had a chart to show what combination of holes i need to achieve a certain amount of degrees
add the number in the holes up together to achieve your final spring wrap.
ie: 2 + 6 equals 80 degrees
3 + 3 equals 60 degrees
