Needles
Coles_55
Eagle, WI
How in the hell do I get them out? I have the top plate off, I have the 2 socket head screws off, now what?
Remove the philips head screw that holds the slide pivot arm to the throttle shaft then rotate the slide pivot arm up out of the carb body so you can lift the throttle slide up and remove it from the carb body.
