Silver Bullet
I started a project awhile back to take my Yamaha 600 SX that had caught a ring on the exhaust port and transplant a running engine in its place. I of course started this a long time ago and now have a few questions.
First, the engine I bought had BR9EYA plugs in it. I always ran BR9ES in the Vmax and BR9ECS in my SRX. I have learned the ECS version has better vibration resistance. What is the difference in these plugs. Should I be running these? Is there a reason they may have run these.
Second, on the used engine I bought there is what looks to be a ground wire coming off the top water pump housing. My previous sled did not have this wire. I am a little confused why was this on there and then if it should be, where should it connect to.
Third, Since it was so long ago since I disconnected the fuel, vacuum, and oil lines I just want to make absolutely sure I get them correct. The two fuel lines out of the pump are the ones closest to the clutch are easy their only long enough to go to the carbs. Then I have a vac line (black) going to the lower case. The other line coming from the fuel pump I have going to the side of the oil pump is this correct? Then the last of the oil lines is the one from the bottom of the reservoir. I have this one going to the underside or bottom of the oil pump. Are these correct?
Thanks very much for your help. Hopefully I can get this thing up and running for this winter.
Silver Bullet
Silver Bullet
Sounds correct to me.
I run the EYA plugs in my 700. They're the same as the ES plugs, but they have a V groove in the electrode. Gives a little better spark, and resist fouling. I like them, and put them in every sled I service as well.
Silver Bullet
Anyone else? How about that wire? Anyone have this on their 600. I read somewhere this evening that the BR9EYA plugs don't have as good of ground. Do you think this was the reason for the wire?
Thanks for any help
Silver Bullet
Thanks for any help
Silver Bullet
