srx track replacement
I have a 1.5 paddle on my viper with stock drivers. Had to remove all the tunnel and cooler protectors. No big deal if you're not gonna stud. Don't know about how the drivers will fit
yup it will fit,you'll have to remove the heat exchanger protectors and possibly the plastic ones in the top of the tunnel.the 9 tooth drivers will also work but if using the stock yami suspension you wil have to trim down the tips of the drive lugs because they will touch the w arm.
