SRX Cover?
Gagt518
Albany,NY
Can anyone suggest a good aftermarket cover that will fill on the srx with a 3" riser and Madd handgaurds? The factory SRX cover i have now is ripped to hell from stretching it over the handlebars so many times. Thanks!
nope, best to get a local upholstery shop to add a small section and sew it into your cover
I had the same problem with my viper. I have a yamaha cover and bought the yamaha accessory handlebar hooks, and the factory cover no longer fits over them. my solution was to only use that cover when trailering, and I just remove the hooks. its a quick loosen of an allen and they are out. I have a loose fitting cover that doesnt work well for trailering that I just use when its in my back yard between rides. Wouldnt work too well for your situation though with the larger riser and handgaurds.
I had the same problem also. I've got a 3.5" rox pivoting riser with stock windshield and Madd handguards.
I am still using factory cover, but I have linchpins for the handguards. The mount stays on the sled and the guards come right off. During trailering, I put the guards in the trunk. The cover is a tight fit, but still works good.
On a side note: the guards have a little play(and I mean little) with the pin, but I'll take the play over having to mess with removing the small *** mounting bolts all the time. I found the largest pin that would fit in the holes.
Hope this helps.
