8BF weights
00sxrjoe
Maine
Anyone use 8BF weights? I pickup up a sxr 700 with them in it. Put motor in another sled tryed them out and was not in pressed at all. Was set up with 14.5mm rollers sum yellow spring IDK what it is. No tip weight and 3.6 heel. Took at 4500 and just all I could smell is belt.
Friend of mine bought a viper with them in it with some red spring I have no idea what it is. I belive it has 15mm rollers with 4.5 tip and 3.6 heel. His had the same prob belt slip rate from engagement up. If I know what the spring was I could adjust from there.
Dose anyone know? Was it some clutch kit? Any ideas. What I looked up they where org used in phazers 97-99
