Hauk clutch secondary
I would assume you have a Yamaha secondary with Hauck spring and helix? Hauck parts are as good as any but your primary and secondary clutches must be tuned to work together. You really need to know what spring and weights are in the primary (front clutch) and what spring and helix are in the back and then someone can give you a better reply........
The outside plate is stamped with hauk powersports. I'll get some more info and photos this weekend.
Must be, I haven't had a lot of time to look at it. I keep it at a friends house who has trail access. What is a roller secondary and would I need to make adjustments to it.
Best bet is to post a pic of the clutch and you can get help from there..
Like these guys are saying, You could have a Hauck Helix or the Hauck Power Shift roller kit is what I think they call it. Its a add on to the stock secondary & cam in a red color that uses the stock style helix's.
