Showing my new srx700 some love.
motorhead327
Northeast Ohio
Finally done! Just went through the sled frt to back. Checked and greased the rear skid, added 4th wheel, flushed and filled the cooling system, cleaned gas tank/replaced filter, drained oil tank and filled with synt oil, replaced all fuel/vent lines, cleaned carbs+checked floats, cleaned clutch, cleaned airbox, new plugs/plug caps, adjusted all cables, replaced headlight bulb, replaced trailing arms/bushings, greased all radius rod bushings, new spindle/ski bushings, one radius rod, recharged frt shocks, new skis,carbides,hardware, cleaned power valves and set, drained chaincase and filled/adj and couple more goodies. I was asked by my fiance if I wanted to live in the garage,lol.
Thanks fellow members for all your help. :yam:
Doing the same thing here!! Half the fun is working on them yourself!!!!Sounds like your sled is ready to go!!! Let it snow!!!!!!!!!!
AMEN let it snow...im about to do the same thing....think i should pull out the jackshaft and driveshaft bearings and grease them????
yeap got mine dune about 7:00 pm same thing grease & clean carbs & wax ;)! .in garage for about 3 weeks.spent about 80 bucks on her this yr.ready too ride. :letitsnow :letitsnow
Hell Yea, It at least gives a world of confidence that it wont be you sitting on the side of the trail. Maintance pays off in the long haul. My father tells me that im a perfectionist, but hey its all good. I have 18in of snow right now so cant wait for the weekend!!!
Spinner18 said:
do these have a grease zerk on them? if not, how does one go about greasing them, I am swapping out a track so I will have it out.
My opinion on that one bearing is, if you have the track out change the bearing. It gets so much abuse from the snow, and you need to take it off anyway. Do you know how many miles since it was done?
No idea on how many miles. Why do I have to take the bearing off? I've changed tracks on many Polaris and never has to take off that bearing. Normally I can pull the speedo housing under the clutch, take off chaincase cover, remove bottom gear, and I have always slid the shaft first towards clutch side and it cones out if the chaincase, then driveshaft comes out.
Different on a yamaha?? Also how much is the bearing? Anyone got an oem part number for me?
