Aftermarket Oil cable
maximus070301
Minnesota
So I just bought a 02 viper with a 6 inch riser on it, it also has a aftermarket oil cable on it. Could some one tell me if there are any specs on adjusting it, here is a picture. If someone had one like this that could measure the distance between the two nuts that would be great. Otherwise is it true to say that the bigger the gap in the nuts the more oil? Any help would be great![/IMG]
I would say yes. Anytime you tighten a cable housing the more throw it has. If you pull the cable from the adjuster you can watch the pump arm move. Spec is from 20-22mm from octagon barrel to end of cable housing when pulled taunt by hand. Make sure to adjust throttle cable first if needed.
