Yamaha OEM drivebelt differeces ???
Lasse
SWEDEN
I need to know what the differences is between these drive belts :
* 820-17641-00
* 89X-17641-00
* 8F2-17641-00
:confused: :confused: :confused: :confused: :confused: :confused:
NOT MUCH, MAYBE COMPOUND AND WIDTH. 89X I BELIEVE SUPERSEEDED THE 8F2 BELT. THE 820 BELT WAS BEFORE 8F2 AND WAS SLIGHTLY WIDER. 3:16 (yammie tony)
YAMMIEGOD3:16 said:
Not much,
maybe compound and width.
89X I belive superseeded the 8F2 belt.
The 820 belt was before 8F2 and was slightly wider.
1. So which belt can I buy at the Yamaha dealer today ??
2. Which belt to use on a Exciter-570 ( <---1990 ) ??
WATCHMAKER said:
90 Exciter with stock Yamaha clutches uses the 89X. If you have a factory Comet then the 87X.
* ( 1987 - 1990 ) Exciter-I have the "YPZ" clutch.
* ( 1991 - 1993 ) Exciter-II have the "YXR" clutch.
I have never heard of any EX-570 sled that have a "COMET" clutch from factory ! :confused:
YAMMIEGOD3:16 said:
None of the above belts.
Get this belt instead: 89L- 176410-01
Is not that belt for the ( 1991 - 1993 ) Exciter-II ???
