Need a little help guys - Viper Charging System
sxr700m
Northville
I have a question. My 2004 Viper 700s seems to be losing it's charge certain times. It seems to happen on really cold days when I decide to run my hand warmers on high. Once I ride a while with the warmers on high and I turn my sled off and then some time later go to use my electric start the battery will be dead. Let me know if some of you may have experienced this or have an idea what it may be. I really appreciate any help.
Weak battery will show up on cold days and as mrviper said make sure you turn the key to the off position. If you use the kill switch there is still power going to the power valve motor and that will kill the battery.
