98mtnmax
I have a 98 mm600 with the smart carbs and my throttle response really sucks. I will get on the gas from idle or a little above idle and the sled falls on its face and then takes off. It has a brand new belt on it and the gearing is pretty low (only tops out at 60). Would this be a clutching issue or an issue with the engine itself?
first place i would start would be to clean the carbs. if they are clean and the problem still exists, you can run a series of diagnostics on the components involved with the smart carbs to rule out that. dirty/worn clutches can contribute as well. a little more description will aid in diagnosis.
gild
Isn't the 98 600 a triple ?
goody_700
Check for fouled plugs as well as the above^^
the 600 in 98 was still in the twin mode.gild said:Isn't the 98 600 a triple ?
I used reed spacer to help the throttle response!!! it helped a lot with the TR above idle, I still have a slight delay at base idle...
look in the tech pages, and do a search for mods for the 600 twin!!! Reed Spacers, Reed notch, Air Box, Head Gasket...... I think would all give you results your lookin for!!!
after you make sure your carbs are clean and plugs are good of course!!!
cacsrx1
If its a twin the clutch needs to be serviced. They were hard on clutches.
98mtnmax
I redid the clutches at the end of last season so i dont think that would be the culprit. Where can i get a set of reed spacers?cacsrx1 said:If its a twin the clutch needs to be serviced. They were hard on clutches.
here is a set for a triple..... but they might fit a twin...... if you search yahoo or google they're easy to find!!!
http://www.benderracing.com/Reed_Spacers_s/454.htm
you could also call Bender.... they might still have them for the twins!!!
