Scherbers4
Just wanting to get your guys information on handle bar risers. I want to get some, and seeing what you guys like and what size you are running. Most likely I am going to go with 4". Do you think I am going to have to get extensions? I also like the articulating risers.
I was stretching it with a 3" riser so a 4" probably
Spaz's SRX
Do a search and you'll find tons of data.
IMO go with ROX 3.5" pivoting riser and with this you will need to extend oil, throttle, and brake lines.
This is what I am running, and love it. The oil line is not necessary, but i would recommend.
![](/styles/vip.gif)
super1c
Super Moderator
Spaz's SRX said:Do a search and you'll find tons of data.
3.5" is max, and you have to nudge the brake handle forward on the bars a tad. I would recomend the 3.5 like spaz said. The half inch is not worth the work of extending cables. I run a 1 inch block riser with a 2" pivot riser. Perfect for standing or sitting. Of course im only 5'7" but ive seen lots of guys over 6' running the same thing and being happy with it. CCC
Truckkid42
i am 6' and had a 3 1/2 i think and liked it. still wasn't tall enough, so i went wit a 6 inch riser and a 2 inch pivot adaptor for a total of 8 inches of riser. now im loving it 100x more.
I'm 6'1" and just put a 4" Rox adjustable riser on my '02 Viper. I also have a seat riser on mine. YES you need the '03 Mountain Viper cables to make it work. I had a 2" on last year, and the 4" feels that it will be a lot better to ride with.
you have a great thread in the tech section,
here it is:http://www.totallyamaha.net/forums/showthread.php?t=27347
WNYViper
I have a 3.5" TruVert riser on my Viper, had to get the Viper Mtn cables (I prefer to have the slack in the lines). its a nice height for sitting and works out alright if I stand up a bit (6'3")
I run a pivot and block on my SRX that nets out at about a 6" rise. I run RSI extra long braided cables. At 6'1" I can stand comfortably and with the Boss seat the 6" rise works good when sitting.
Bob
Bob
Scherbers4
Thanks for the advise guys, I think I am going to go with the ROX 3.5 Piviot riser.
Truckkid42
good choice, now get handgaurds and you'll be all set.
