00SRXWHERRY
Ok, today I started to reasemble the engine. In putting the reeds back together I noticed that on the boots the orange ruberized coating on the inside was bubbling. I ran my fingers accrost it and the coating started to come off. So do I need new boots? I'm worried it will continue to peel and fall into the case.
![001-12.jpg](http://i285.photobucket.com/albums/ll65/wherryb/001-12.jpg)
You could either replace or just scrap off as much as you can and use them,, The engine will digest that just fine....
00SRXWHERRY
Ok, I will work on getting it off. Other than where it's bubbled it won't come off.
extremelyfastmax4
somebody painted them they should be black, , use mr gasket remover and spry them it will wipe off with a rag. AL
theyre not painted. mine looked the same way the other day when i replaced my stock reeds with the carbontechs. if your engines gonna go down because of that then so is mine so is mine. lol i think they will eat that up and spit it out without any issues.
ottawaair
common issue.
00SRXWHERRY
Good to know thanks guys
