kirk700 srx
When mounting the cylinders on the motor where does the #1 cylinder go? Pto or Mag?
kirk700 srx
Well that eliminates another thing that could be causing my sled to work great when its cold but not when its warm! I fixed the leak in my mag side head, cleaned up good as Mrviper suggested. Added new gaskets and the sled is still not preforming the way it should!
Mac
What am I missing. All the cylinders are the same?
the tree man
I thought the mag side was always #1 cylinder because that's where your timing is set.If it's the PTO side I just put my base gasket in upside down.Plus my jetting stagger is wrong but everything works fine.So #1 is PTO?Jesus H!!
Left to right sitting on sled,,,,123...
kirk700 srx
Yeah they are all 8dn00 on the 98 srx but one of them has # 1 Stamped on it
Mac said:What am I missing. All the cylinders are the same?
man on man Kirk..you having problems with your SRX to eh!Mine is sitting now till early next year.Won't pull rpms ,pv's are a problem and maybe servo.Might as well just ride my 600 this season,it never gives me a headache.Maybe it is time to retire the old SRX and put it up on a Pedastol in the front yard.
kirk700 srx
I have lots of servo motors here, maybe ill swap one out and see if thats whats been bugging the poor girl!
