Headlight Adjusment SRX?
Gagt518
Albany,NY
Is there any way to adjust the headlight on our SRX's? Since i put the SCIII skid in cant see much at night. The sled is across town or i would check for myself.
I had the same problem when I put drop brackets on my rear suspension, the sled was nose down too much to adjust the headlamp up enough. I couldn't adjust it properly until I long travelled my front end and levelled the sled out. I actually broke the little tab at the top of the light housing trying to adjust it up enough to shine properly and had to replace it. Watch that you don't do the same thing.
Gagt518 said:
Alright cool so theres a little adjustment to play with
Yes, there are two screws at the bottom corners of the headlamp housing inside the hood. Guess I forgot to mention that... Those are the ones that you shouldn't screw in too much trying to adjust the headlamp up.
