Bender clutch kit ck 9870?
kking32
moncton canada
hey guys, wondering if anyone has tried this older kit on 98-99 srx's? i came across one that is pretty much new, thanks
This kit is specific for a 98 700 only. It throws a big helix to bring down real poor primary clutching. It,s a band aid clutch kit tuning with the secondary.
It,s slightly better. The 00-02 srx primary set up is by far the best.
RE: clutch
thanks, i have a set of 2001 weights, the stock primary springs on the 99 and 2001 are the same, what else would i need to run the 2001 set up? is the inside of the primary designed different?
Try to find a w-w-w yamaha primary spring & your good to go
RE: clutch
ok. thanks again! TURK !! the 01 weights and a w- w- w primary spring, should the secondary be adjusted from 60 to 80 like the 01?
the stock primary spring on the 01 is a y-w-y the same as the 99. also would it make a difference in changing the bottom gear from a 37 to a 38 like the 01,
