Oil
OldBlue#2
Minnesota
Just curious what oil everyone is using and what they have had good luck with. I have been using yamalube, but I'm looking to switch to something cheaper. I know there is almost 40 pages on oil in another thread, but I really don't want to read through it.
I have been using Shell Blue oil for the that three years. No problems as of yet. $30 cdn for a 5 liter jug $21.99 when on sale. Not sure what Yamaha lube cost. Try not to go to the dealership unless I have to.
I have been using Mystik from Farm and Fleet. I was never one of those to stay specific to a certain type of oil or anything, but this stuff is cheap and it runs just fine in my sled. I havent had any problems with it fouling out plugs rapidly or anything. I'm not going to tell you its the best oil out there, but for $20.00 a gallon for full synthetic and 2 years of no problems with it, I'll stick with it. Works for me. Just my .02
Thanks for the pm j_k_auto, but the amsoil prices are a little more then what I want to pay.... I did a google search that mystik, sounds like people are pretty happy with it, I might have to try some.
You are :wel:
Look decent, Ill have to find it! Made by citgo. Specs look good too.
M y s t i k L u b r i c a n t s • 8 0 0 / 2 4 8 - 4 6 8 4 • H o u s t o n , T e x a s • M a d e i n U S A
P R O D U C T I N F O R M A T I O N
M 2 0 0 7 5
Mystik JT-4 Synthetic 2-Cycle Snowmobile Engine Oil utilizes premium synthetic base oils combined
with a special synthetic additive system to provide superior cold temperature protection and quick
starts in extreme cold. Its unique tri-blend of synthetic components provides ideal low temperature
performance and quick starts in extreme cold. This balance of synthetic components enhances fuel
economy, improves cold temperature performance and high temperature thermal stability.
The special additive system is designed for specific use in Snowmobile engines. It provides the best
protection against engine wear, rust and corrosion, and ensures engine cleanliness. The advanced
formula used in Mystik JT-4 Synthetic 2-Cycle Snowmobile Engine Oil far exceeds Snowmobile engine
requirements for an API TC, JASO FC and JASO FD quality oil.
• Provides superior protection in temperature extremes
• Permits quick-fill lubrication flow during cold weather start-up to help reduce wear
• Promotes longer engine life through increased wear, rust and corrosion protection
• Improves equipment productivity and reliability
For use in all air-cooled or liquid-cooled 2-cycle (Injector or Premix) Snowmobile engines including
those manufactured by Arctic Cat, Ski Doo, Polaris, Yamaha, and other original equipment
manufacturers. Mystik JT-4 Synthetic 2-Cycle Snowmobile Engine Oil is ideal for engines operating in
extreme cold temperatures and where performance demands the most from your oil.
Mystik JT-4 Synthetic 2-Cycle Snowmobile Engine Oil is recommended for use in 2-cycle Snowmobile
engine applications requiring API TC, JASO FC and JASO FD quality oil.
NOT FOR USE IN OUTBOARD MARINE ENGINES!
DESCRIPTION:
FEATURES:
RECOMMENDED:
APPLICATIONS:
TYPICAL PROPERTIES:
D a t e 1 / 0 9
MYSTIK® JT-4® SYNTHETIC 2-CYCLE SNOWMOBILE ENGINE OIL
Material Code 663077002
Gravity, ASTM D 287, °API 32.9
Density lbs/gal 7.17
Flash Point, ASTM D 92, COC, °F (°C) 230 (110)
Pour Point, ASTM D 97, °F (°C) –54 (–48)
Viscosity, ASTM D 445
cSt @ 40°C 54
cSt @ 100°C 9.2
Viscosity Index, ASTM D 2270 152
Visual Color Purple
Sulfated Ash, ASTM D 874, m% 0.015
TBN, ASTM D 2896, mg KOH/g 4.3
I called my oil supplier, which a Mystik dealer. For some reason they cannot get the synthetic Mystik oil. But, I can order directly from Mystik. $24.50 gal. I am thinking my supplier is hesitant on ordering in large quantities to aquire a better price. I am interested in the Mystik oil. I will be placing an order at the end of this week for a case. Al
