Stuck Primary errrrrrrrrrr
tagoes10s
Niles, Michigan
Well I broke a puller today trying to get mine off also. The end of the puller bent and then messed the treads up on the crank coming out. I just read up on the hydrolic method so I guess I'll try to order a new puller, are EPI the best? Anyone know the tread size of the crank because I'll need to tap the treads clean????? once I get the primary off.
