killerklown
OK, got my powervalves back in, must not have cleaned one enough, or missed the adjust ment some, but the light still flashes the PV error on my 2001 SRX 700. Long story short I don't have heat or tools until Sunday, but the trails just opened, and everyone is heading out, so will I screw up my engine riding with it like the for a few days? Losing a little performance is acceptable for the first ride of the year... Or do I need to sit it out to be safe????
harness racer
pull the valves wide open , wont be a break down issue just poor low end performance , if the valve is in you will creat to much cylinder heat and potentially melt down 1300degrees f melts aluminum , i know lol.....
viperking
i believe you would be fine, people ride all the time with stuck and pulled through pv's and don't even know it
harness racer
if the cables broke leave it out (valve)
killerklown
you guys rule, thanks!!!
