im having problems with my mm the number one cyl not running. ive cleaned the carbs to perfection, fresh gas, new plugs, 120psi on both sides. it runs good for about 10 min, then it just drops. ive had the carbs off 5 times to clean them. it seems like it isnt geting fuel to it. the jets are clean, every thing is in spec. please help me
Is the float sticking or inlet need sticking.. is the fuel line full from the pump to the carb?
dukie169 said:im having problems with my mm the number one cyl not running. ive cleaned the carbs to perfection, fresh gas, new plugs, 120psi on both sides. it runs good for about 10 min, then it just drops. ive had the carbs off 5 times to clean them. it seems like it isnt geting fuel to it. the jets are clean, every thing is in spec. please help me
I'm not sure if your application has them but did you pull the needle and seat and look at the fuel inlet "top hat" filters/sceens?
hereismylife
What does your plug look like
