spark plug difference
srx2fast
barrie
hey guys. i have been doing alot of reading on spark plugs and from what i have read the white porclean part of the plug should be a tan color or a little darker? So i decide to take my plugs out and check them. When i did 1plug seemed to be perfect, 1 plug seems real dark with carbon depoists and the other one is really clean and i mean really clean. i'm not a tech guy butcan do mechanical things with ease. So my ? is, If i took my carbs off and set everything to the way the good cylinder is will this solve my problem and will all my cylindrs run the same. Oh i forgot to mention it's a 2001 srx stock. Will this also put me back to optium running perfomance for stock. Please help thanks.
Guys someone most know something...... come on help me out here just a little comment would be great. thanks
Were the carbs cleaned good before you ran it and checked the plugs?Could be numerous things causing this.Dirty carbs,air leaks....the list goes on and on.If the really clean one has a piston that looks really clean you could have a head gasket leaking coolant into that cylinder.Need more info for the Guru's here to help you out.
