reddog mmax 700
can some one tell me if the first generation heel clickers any good? i mean whats the difference between the first generation and the heel clickers they sell now?
they were "ok", but you had to notch your sheave with a grinder and they only had 1 hole to place weight(rivets), the newer 40-10's bolt right in and dont require grinding on your sheave and have 2 threaded holes for weight placement, the hardware is much simpler to use. I would get the newer 40-10 if you can.
YAMMIEGOD3:16
ONES I USED WERE 40-10YB. THESE WERE THE ONES DON HERE EXPLAINS AND DROP IN LIKE A GLOVE. 3:16 (yammie tony)
reddog mmax 700
kk
thanks guys
thanks guys
