'81 Enticer Rear Suspension Mod
SAFASTRO
Calgary
I have an 81 Enticer 300 and 340 and NEED more suspension travel on these things. I want to hit some mountains, and have seen alot of guys turning them into "mountain sleds"!! What suspension setup would be the best? I'm looking for ease of conversion, relatively low cost, travel height of 6" to 12", and probably a 121" track for the 300, and a 136" track for the 340.
Any help and/or "how-to's"would be fantastic!!!
Thanks in advance!!
Your best bet is to pull the suspension on both those sleds and take a look at them sitting out with no track on them. Maybe take some measurements like width of the crossbars and space between them. Then go out to swap meets where you can physically see and measure the parts you are looking for and find a suitable suspension that way. Otherwise you are probably going to have some major modifications to do. Also keep in mind with a longer track, you are going to want to at least pull the snow flap and maybe extend the tunnel if you wanna keep a flap..
