Should my rotor be loose on my viper
turbotod
Rochester,N.Y.
The brake rotor on my sled has side to side and forward to back play in it. How much play should there be if any? Thanks for any help
Some back and forth play is fine but if you ever have the rotor off for any reason, take a look at the key-way that holds the rotor on the jack shaft. Had to replace the track on my SRX last winter and my key-way was worn.
