f7 clutch in 01 srx
srx2fast
barrie
Guys do you know if a primary out of a f7 would fit in a 01 srx. I'm not sure what year the f7 is i believe its an 04. I know i would have to change the springs and stuff i really just need it for the sheaves. Would i lose out by putting this clutch in or would there be any gains? thanks
I believe you should get your carbs set up first before you go put an arctic cat clutch on a sled it was never designed for I deffinitely don't reccomend it.
Pull off your carbs, go through them all check your main jets and your needles and report back tell us what you have got. We'll help you get it set up and running right. Then you can worry about tuning it.
