crazzygunner
friday I put some miles on my exell 3 and worked like a champ all the way until
it was parked on saturday I noticed that the hifax was warn so to be safe i replaced it. went out again stated out well the first 5 minutes and it wouldent go past 20 mph or 3 grand and we went home put in plugs and bipased the switch on the carb linkege same problem then we checked the carb it was clean as a wistle and the float was adjusted right and we hooked up the wires again by the 3rd lap around the house full throttle was a crawl
what should i check now any help whould be apreciated.
Evan
Evan
crazzygunner
Its solved I checked spark what I should have done first and found out one side was not sparking grabed the boot from the other side it did spark with that two spark plug boots later for $6.00 I was solved.
Evan
Evan
