Viper Air Box Gutting
Dont do it unless you want to rebuild your motor. Leads to ALOT of burn downs....
The airbox in the Vipers is very good, no way you are going to improve by gutting.
Yeah I agree leave it stock. Your going to notice a difference for-sure especially with some jetting but it isn't worth it.
Srx Box
What about for a non trail ridden sled? Sled is just used for speed runs
This is a 2000 SRX700
Just buy the Thunder Products TPI's. I have them and they work great. I open them on warmer days and close them on colder days. You can adjust in between too. I have the knobby style. Just be careful on piped Vipers. I left mine wide open back when I had the CPR pipes on when it was -4 degrees F. and lost two cylinders. Stock I have ran them down to around the same temp with no issues.
http://www.thunderproducts.com/tpi_valve.htm
