1998 srx chain case problem
panthers06232
jackson michigan
i have a srx 700 the chain had some slack and eventually needed to be changed when the new one gets on it how much will it effect the overall performance of the sled because i was noticing the track spinning and not hoocking up like it should could te bad chain cause this problem
Your not going to notice any performance difference with the new chain. If the track was spinning and the chain wasn't jumping on the gears, you were not losing anything. Not hooking up the track to the ground is a track problem and or suspension set up issue.
