jetting on a 04 700 viper with aaen pipes
cattechsummitrider
sask
Hello, i just bought a 04 700 viper mtn it has a tempra flow on it, the guy also had a set of aaen pipes for it that he never put on so i got him to through them in on the deal, I was just wondering if i should wrap the pipes in header wrap(to keep the heat in) and what the jetting shoud be aprox, thank you ! Great forum!! lots of info!!!
i would recommend wrapping the pipes w/header wrap. check out my avatar. also, i can help you w/jetting, as i have these pipes. what's your altitude and riding temps in ferenheit?
Me I would take the tempoflo out and run jetting specs for those pipies 0n the (rich!!) side and adjust there are guys on here that can get you right on for elevation.
Yeah, please get rid of the tempa-flow. I HATE those things. Just go off the jetting specs I sent to you, w/NO tempa-flow and you will be fine.
I will look into mine. Cant remember. My 2004 MNT Viper has ceramic coated CPR Simmons pipes, Peak heads, motor mods and the ATTAC installed. Works like a charm!!!
