1sickviper02
when i studded my viper 2 years ago i got the "recommended" length of the studs, and they are waaaaaaay too short...Can i get longer studs and put them back in the track that i'm taking the old ones out of? and what length studs should i get..the track is .92 i believe and i have 1 inch studs now...
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
You should use the 1.005 studs from woody's, those 1 inchers should be perfect, you do not want them sticking out more then 3/8. I am running 1.080's in my 1" track and they stick out the perfect amount. You should not have a problem with the 1" studs in less they are worn down. The thing people don't think about when they stud there tracks is even though it does'nt sound like it is sticking out far, it is because it goes further through the track then the measurement says. Go with an inch stud and you will be perfect. As for the reassembly, as long as the old holes are not stretched out to bad or ripped, there is no problem. But definitally go with 1" studs or the 1.005 woody's (I would go with the woody's)
