uncletom43
i have a 1998 MSRX and i have burned the #3 cylinder for the 3 time the first 2 times was caused by a peice of foam from the top of the airbox that i found after the i redid the cylinder the 2 time it burned down i removed the foam and changed the reed cage also a new cylinder and piston and head but i didnt change the base gasket under all 3 cylinders i just put sealer on the top of the gasket on the one cylinder so now what happened it burned down again i put new crank seals last season so i dont think its that so anybody have any ideas what it could be it needs a new cylinder piston and head again
