Rumble after new suspension bearings
destey
Vermont
99 srx700. I removed the rear suspension and replaced all the bearings in the idlers, put it back in and the sled still makes the same rumble as before. Is this normal to some degree? Some of the bearings I replaced definitely needed replacing.
I set the track tension up as stated in the FAQ, so I think that's ok. I didn't replace the driveshaft bearings, could this be where the noise is coming from?
