Heelcliker kit srx 2001
skimau
Riviere-Heva Quebec canada
ok I just buy a heelcliker kit but I don't have the nylon washer can I put the original nylon washer or it's dangerous because in the installation guide it's mentioned ''do not use the original washer...'' and if I can't put the original washer what is the reason. And where can buy this washer.
Thank you for your answer
Did you buy the kit new?If so send it back as it's missing pieces or you may be able to get the washers from where you bought it from.The Yamaha washers are thicker I think is why you can't use them.
If weights are tight with stock washers you are fine.
Hardware stores sell a lot of washers that would work. Your overthinking this. I have used hc,s since thewy 1st came out in 2001 & never had an issue using stock washers as long as there was very little side to side play.
