Servo motor...
Netefrog
ON, CA
This year when I was doing my fall inspection of my sled I decided to actually take the servo motor apart and inspect the gears etc. Just got my valves back today (thanks again Rich) and it's time to put it all back together. Is there anything I should double check before I put it all back together and hit the trails??? Any advice/warnings on resetting the cable/valves or any other advice would be appreciated.
just get her done and get sledding....you'll find out soon enough if it was done right..that is why us guys have tools..to fix the problems as they arise..now PIN IT!!!! ;)!
I set my PV's with the 3mm instead of 2.5 mm method as most do.Since I saw some pull thrus starting,I decide to get it a tad more slack and so far so good.
MONSTER- Thanks for the ADVICE buddy. lol Pin it I will. lol I'm off tomorrow so my goal is to be able to ride to the Golden Griddle for lunch by noon. My exhaust valves are now reinforced so I will be setting them to 2.5mm with no issues.
Anybody else???
