hauck helix question
What is the X style? I have a hauck also... it's nickel plated and that's as much as I know about it (it doesn't look multi angle but I don't know if that is perceptible to the naked eye).
Why wouldn't it be good for loaded dn 20s with 4.5 in each hole, a red spring wrapped at 80 and stock primary spring?
I'm je because I have a 52-46 micro Belmont helix with 4.5 each hole red at 80 and stock pri spring... Runs pretty well all around.
hauck uses a letter code for the different angles instead of stamping the actual angle. i see in your thread you have a G so yours is a diff angle then the X, i have a K i think 45/41
