yamie 1
what can be done as a preventative measure to keep the wiring harness from chaffing under the engine. i might just as well do something before a problem occurs. thank you
You can use some automotive flexible wire loom. The stuff that the wires in your car run through to protect them. It comes in colors if you wish.
