Which Washers?
thunder66
fenton,michigan
Just cleaned my primary clutch parts and realized there is a difference in the washers that are adjacent to the weights and rollers. They are practically identical except that half are clear/translucent and the other half are solid black. They were dirty enough when I took it apart that I didn't notice the diff... anybody know which go with the rollers and which go with the weights?
grapeape said:
on the apex they are black on the rollers, white/clear on the weights
Thanks! I just figured it out with by brilliant deduction skills... the pins that the weights and rollers rotate are two different sizes and the roller pins wont slide through the clearish washers.
